need someones boost by gear graph calib.
first time with s300 and boost solenoid, i dont hav clue how set up boost by gear, and which method to pick..... running turbo gsr dual 38 gates with 10psi spings and everything is wired up correctly...just need good guidline to set up boost by gear than i can go from there..thanks
Re: .
1.85gsr 9:1cp. built gsr head, .5 valves,springs retainers,itr cams, toda cg,68mm TB, victor x manifold, t3 topmount S362 turbo,3" dp,dual 38mvs gates 10psi springs, id1000cc injectors,single 255 pump,.. anything else you need? my email is kmaz93da@yahoo.comRevspeed wrote:if u still need thiskmaz93da wrote:No buddy has boost by gear?
whats ur setup
i have alot of them lol..........
Re: .
kmaz93da wrote:1.85gsr 9:1cp. built gsr head, .5 valves,springs retainers,itr cams, toda cg,68mm TB, victor x manifold, t3 topmount S362 turbo,3" dp,dual 38mvs gates 10psi springs, id1000cc injectors,single 255 pump,.. anything else you need? my email is kmaz93da@yahoo.comRevspeed wrote:if u still need thiskmaz93da wrote:No buddy has boost by gear?
whats ur setup
Re: .
any updates on what kind of power that turbo makes?kmaz93da wrote:1.85gsr 9:1cp. built gsr head, .5 valves,springs retainers,itr cams, toda cg,68mm TB, victor x manifold, t3 topmount S362 turbo,3" dp,dual 38mvs gates 10psi springs, id1000cc injectors,single 255 pump,.. anything else you need? my email is kmaz93da@yahoo.comRevspeed wrote:if u still need thiskmaz93da wrote:No buddy has boost by gear?
whats ur setup
