Hondata Boost Controller
I have the blue Hondata Boost controller hooked up, and working, but I need to make sure I have the setup correct...I have a Tial 44 wastegate with a .5bar/ 7.2 pound spring...Its a normally close boost controller if I am correct so in the fixed duty cycle method, what do I set the solenoid activation pressure at?? So do I start with a lower percentage duty cycle and work my way up to determine the correct boost I am trying to reach??
booost control
ok cool, thanks, so just make a note in the notes section on my smanager of what duty cycles produce x amount of boost....thanks again and what would be the right Solenoid Frequency to enter in the Variable Frequency section??....
