Rich at low load and light throttle help
Tsuchinoko
Post by Tsuchinoko »
Hello,
I have a issue, i have my map tuned, the car is running very very good BUT sometimes at a very little throttle the afr reads very rich.
The first column is tuned for about ~13,8 - 14,2 and it reads ~11,8 - 12,4 sometimes richer that this, sending the traditional sound by the exhaust pop pop pop.
I think is something about with the TPS, by the moment my readings are:
Fully closed: -1,33%
Fully open: 100,36%
I have the overrun fuel cut at: 0,5%
And the delay at: 300ms
The map table is stock.
I don't know if the injectors are not stopping supplying fuel or something like that...
This issue started after i upgrade to the beta version 1.4.7 but i already made a test with the 1.4.4.1 version and the issue still and then i returned to the 1.4.7 beta version.
This is happening with about ~8% of throttle and in ~2800-3000rpm.
I already tried took some fuel in that cells but the issue continues.
Should i take some degrees in the ignition columns to see what happens?
Somebody have a clue what is going on?
Those who know don't tell, and those who tell don't know.
Tsuchinoko
Is it possible to a bad TPS make this symptom?
What wideband are you using?
Tsuchinoko
I'm using innovate.
BTW yesterday i read the throttle position again and some strange readings was shewed was like 20% fully closed and 60% fully open, i tried to do a couple more time and the values was always this strange. After that i disconnect the tps sensor, the plug was a bit tight i took it off and with the blower i cleaned the plug. I made the readings again and they was ok like -1.22% FC and 100.36% FO. Put the car running and went for a test run and the AFR was perfect like the way i tuned for.
Does a bad TPS can cause this symptom???
I would recommend replacing the TPS as it sounds like it is the source of your problems.
