FlashPro Manager software
civicRSA
Posts: 132 Joined: Thu Nov 12, 2009 11:29 am
Post
by civicRSA » Thu Apr 29, 2010 9:11 am
Above zero strim it will show the + values. Below zero there is just a blank for the strim.
Pir8pete
Posts: 92 Joined: Sun Jul 19, 2009 7:47 am
Post
by Pir8pete » Thu Apr 29, 2010 10:03 am
[quote="Hondata"]Pir8pete: Shift+F1 or View->Normal
How did this get changed? I never touched anything just ran the install over the exsisting installed version. Is this a default setting in this .1 version?
Posts: 10616 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Mon May 03, 2010 2:30 pm
civicRSA: Does not do it here. What regional settings do you use?
civicRSA
Post
by civicRSA » Mon May 03, 2010 8:23 pm
Regional settings checked all reset. Still doing it.
Post
by Hondata » Wed May 12, 2010 1:21 pm
With V1.1.5.3 we have added the gear ratios. These are used by cruise control to determine if the clutch is slipping, and will cancel the cruise control at a certain point.
Would someone with a Euro CTR try a MAP calibration and tell us if cruise control works in 6th gear? You'll need to change the ratios from the default.
civicRSA
Post
by civicRSA » Wed May 12, 2010 1:26 pm
I'll get on it. Will report back.
civicRSA
Post
by civicRSA » Thu May 13, 2010 2:32 am
Confirmed. Speed cruise in 6th gear works on Euro CTR using MAP calibrations.
Well done Hondata
Post
by Hondata » Thu May 13, 2010 9:01 am
Thanks for checking this.
Gernby
Posts: 307 Joined: Thu Oct 29, 2009 2:53 pm
Post
by Gernby » Thu May 13, 2010 1:44 pm
Will ignition retard by gear be available for S2000's anytime soon?
'06 NFR S2000
civicRSA
Post
by civicRSA » Thu May 13, 2010 11:30 pm
I see the function to disable the second coolant temp sensor.
I thought that you could disable it by un-checking use second coolant temp sensor for fan control.
Does this have and influence on the wideband input here?
If disabling the ECT2 can you not use ECT2 to control the fan?
Post
by Hondata » Fri May 14, 2010 7:53 am
Gernby: probably not.
civicRSA: It is for race cars.
Gernby
Post
by Gernby » Fri May 14, 2010 8:14 am
Hondata wrote: Gernby: probably not.
Is that due to a technical difficulty, or just due to priorities?
'06 NFR S2000
civicRSA
Post
by civicRSA » Fri May 14, 2010 10:33 am
Hondata wrote: civicRSA: It is for race cars.
So when using ECT2 for a wideband input which do you disable?
ECT2 sensor or ECT2 fan control
Post
by Hondata » Mon May 17, 2010 11:32 am
Gernby: I have not looked to see if it is possible for the S2000 yet, but at the moment it is not our highest priority.
civicRSA: Just disabling the ECT2 should be enough.
Gernby
Post
by Gernby » Mon Jun 07, 2010 10:43 am
Now that the "Return To Stock" function has been moved, how can it be uploaded to the Secondary Calibration on the FP? I always keep the RTS calibration there as a backup.
'06 NFR S2000
