Datalogging Brake Pedal Switch Sensor
FlashPro Manager software
lukits01
Post by lukits01 »
I noticed on the K20Z ECU pin-out diagram there is a brake pedal switch pin.
Would it be possible to add the brake pedal as part of the sensors to datalog?
or are there any plans in the future to implement this?
soxfan143
Post by soxfan143 »
Why? Just curious.
lukits01
Post by lukits01 »
as a driver improvement tool, i.e. analyse driver performance(speed) through a course with braking vs throttle application, minimise coasting, etc. I'd take steering angle application too, but I think that's not an option the Hondata can handle :D
Gernby
Post by Gernby »
There were TONS of parameters like this on the CAN bus of my '06 Lexus IS350. It even had accellerometer data for the stability control. However, the FlashPro is a tuning tool, not a performance driving tool. It would be sort of an odd direction for the FlashPro to go if it started datalogging parameters totally unrelated to engine performance.
'06 NFR S2000
lukits01
Post by lukits01 »
I don't see why the datalogger cant be used for both.
Although if that is Hondata's stance, then I'll make do with what I've been given. It's already a pretty useful driver performance gauge as it is. Love the datalog button, I use it religiously. Just saying, since the ECU is already receiving the signal, maybe it wont be too much effort to put it into the datalogger.
BAKA!
Gernby
Post by Gernby »
Don't get me wrong. I would like to see them add some features like this, but I wouldn't want them to divert their development efforts to achieve it. It might be a slippery slope, where people would start wanting them to add a bunch of new functionality to FlashPro Manager to view lateral accelleration, then GPS input, etc.
On the other hand, adding much more data to the datalog would fill up the Flash memory faster.
'06 NFR S2000
Gernby
Post by Gernby »
BTW, I believe you can buy a OBDII / CAN datalogger from Bowser electronics pretty cheap. It probably has the data you are looking for.
'06 NFR S2000
