D17a2 ecu?
Wannabfast
D17a2 ecu?
Post by Wannabfast »
is there one? if not when are you going to make it?
Wannabfast
for those of you that dont know what a d17a2 is.. its the 2001-2003 civic ex
D17A2 ECU
At the moment there are no plans to do this ECU.
Wannabfast
if there was enough intrest in it would you consider it? also, would it be possible to use a d16 ecu on a d17?
abmerop18
Post by abmerop18 »
im interested in an ECU for the d17a1 (2001+ civic lx). have your plans to make one changed yet?
honda bob
Post by honda bob »
I am also VERY interested. Please let us know. I know there are hundreds of guys over at 7thgencivic.com that would like to see it happen.
Jaker
Post by Jaker »
If the K20 programmable ECU can be configured for ON/OFF Vtec, there's a good chance it could be used for a D17 application. I've asked the above question elsewhere, but I've not yet got an answer.
Wannabfast
well the problem is that the k20 is configured for I-VTEC, so it will not work with the a2's fuelmap/vtec configureation
honda bob
Post by honda bob »
Come on now...someone make somethign for our ECU's already! :P
JOO
Post by JOO »
I am very very intersted in a ECU for my 7thgen civic ex (D17a2). Please come out with a chip for us. Is it that much different from the d16 chip? Please reconsider Hondata. Peace.
civicdriven01
Post by civicdriven01 »
honda bob wrote:I am also VERY interested. Please let us know. I know there are hundreds of guys over at 7thgencivic.com that would like to see it happen.
I second that. HONDATA PLease help us!
cdmx
hondata s200
Post by cdmx »
Someone with a d17a2 is using a s200 hondata unit....
He says it works fine....only conflict was with his VAFC2
Vtec forever
Agent9
d17a2 ECU
Post by Agent9 »
If and ECU for the d17a2 was made, I'm %100 getting one. I'm more than sure I :) 'm not the only one that would buy one
cdmx
Post by cdmx »
is there anyone that will damn reply???
Vtec forever
opto_isolator
Post by opto_isolator »
Jaker wrote:If the K20 programmable ECU can be configured for ON/OFF Vtec, there's a good chance it could be used for a D17 application. I've asked the above question elsewhere, but I've not yet got an answer.
I posed this question as well on the 7thgencivic forums - the D17 and K series ECUs are similar (heck, the wiring harnesses are almost identical if you look at the pinouts). Heck, most of the sensors that Honda use are similar - and if this is a truly reprogrammable ECU than I'd venture a guess that there's a good chance for it to work...Care to chime in moderator?[/code]
