nitrous aux input/outputs
Danny thats what im trying to use, i thought i had to select an output and make it "always on" to be able to use the settings i enter into the table. I guess for all of the temp ranges i just need to put something retarded like 0-500 and pressures 0-500 so it will just work no matter the conditions. am i right? I know another guy doing this successfully but he hasn't shed light to me yet.
www.MSSRACING.com
9.29 | 6.20 | 167
9.29 | 6.20 | 167
turbotypeR
Yeah, you should be able to choose always on and pic one of the outputs, just don't hook anything to that one. Then do like you say and make the ranges you aren't concerned with an unreachable value. Then you should be able to pull timing at whatever rpm in whatever 3 gears you want. I wouldn't worry about 4th so much. i would do 1st, 2nd, and 3rd. 1st being the most important. Of course, the gears would be chosen be mph.
92 civic Si
best et:9.43best mph:164
