I swapped in a2 cams from a type s with a3 exhaust rockers(Vtec killers) into a a3 head now I can't get the car to start. I tried -20% in cranking fuel trim and it makes a hint that it will fire but then never again till I pull the plugs and let everything dry out.
Do I change ignition values too,change fuel maps? I'm using a stock a2 map as a base map as well.
Or does anyone have a calibration I can use to get it to start?
Are there any sensors I can look at to see what I could change to crank over.
