override radiator fan control
integra579
I have my fan connected to ACC power because i have a bad temp sensor. Now if i was to use the "override radiator fan control" option in s300, would this mean i could put the fan back to stock and not need the temp sensor?
2000 Integra Gs, turbo kit, RC 550 inj, p28 with s300
ECU works in parallel to the fan temp switch(or sensor as u call it),so as long as one is working correctly,then u will be fine.
Its nice to have both working correctly as a sort of fail safe though.
U will need the fan control wire correctly wired to the ECU,which in a 2000 teg(from your sig) i'd assume it would already be wired correct.
If it doesnt work,then suspect the wire is missing.
Dont forget to use a relay to control fan via ECU,dont control it directly off the ECU,the load is too large.
integra579
