Smanager wish list
megomaniac
Another option for widband logging. Being able to log only a selected gear. this will clean up alot of Overrun when on dyno or street. Just be able to make a check box for N-5 gear also have a lean stop logger so if your wide open put 16 as lean over by the time you see 16 in wot you should have the foot off the gas pedal anyways, or you could set it up as dont log fuel cut.
-Plus, when looking at recorded Lambda and going to make a change. after changing the cell can you make it so that 1 cell clears itself. i have started making changes in maps before then customers interrupt me and i forgot where i have already made changes. think this would help us ADD people. thank you.FreshDA9 wrote:Another option for widband logging. Being able to log only a selected gear. this will clean up alot of Overrun when on dyno or street. Just be able to make a check box for N-5 gear also have a lean stop logger so if your wide open put 16 as lean over by the time you see 16 in wot you should have the foot off the gas pedal anyways, or you could set it up as dont log fuel cut.
Make K-Pro work with B series engines.
We would get way more input outputs. Maybe even 8 injectors.
We would get individual coils @ a cheaper price.
We would get extrenal trigger.
I dont know guys I think I am on to something..
Hondata its time to give b series some love! Not sure why it can not work. My buddy is running a VW off of s300.
this is really important!!jun1or wrote:1.) I'm sure it's been mentioned before, but a vertical scroll bar in smanager would be nice.
I run smanager on a netbook (7 hour battery FTW!) but it only has 1024x600 resolution.
2.) The ability to type capital I and D in notes (I believe keys are mapped to "Increase Selection" in the edit menu)
Keep up the good work hondata.
Jun1or
In Crome Pro theres options to select certain injector information. For example High or Low impedance injectors and the voltage compensations, & by manufacturer.That way everything is dialed in for you as far as MS's and dead times etc. Is there any ideas of ever making or adding an options like this for at least a majority of the leading injector manufacturers. I know theres compensations but maybe this would help many people tune there cars.
megomaniac
