Hello
i want to chnage the map sensor . i will use a hondata 4bar sensor.
when i go to
Parameters, then > MAP > then replacement MAP sensor > Quick select > Hondata Omnipower 4bar
and i change then to "Tables" i see only a scale wichever goes only up to 12PSI
but when i use a 4bar MAP sensor the boost tables must go more then 12 PSI.
What is the problem.
Ralf
