data logging motec plm
i use a motec plm to tune and i read some where you can wire it into the ecu and datalog it. is this true if so has anyone done it
motec PLM
Yes you can use a motec PLM with a hondata Hondata has a config file for the PLM so all you have to do is connect it's output to the stock o2 sensors input into the ECU, then all you need to do is select "Motec PLM" under Hondalogger's settings O2 conversion
Make sure your in Open Loop O2 correction.
