Sorry if this question is answered elsewhere. Couldn't find it.
The situation is:
One EP3 civic typer-R with K-Pro installed, one with stock ECU. How is the easiest way to swap K-pro from one car to another? Will ECU work correctly AS STOCK after k-pro removal?
Thank you
K-pro swap for EP3 civic EU
as i understand the k-pro ECU will work on any car with immobilizer off and only 1 ECU must be reprogrammed?Spunkster wrote:No, once an ECU has had a K-Pro installed it cannot be uninstalled. You will either have to swap ECU's and have the immobilizers reprogrammed by a Honda dealer, or just get the K-Pro for both .
Tahnks fo rinfo, but theft reason does not really bothers me) In Moscow if someone want to steal your car he will 90% do it anyway AND using a pick up or something AND that will probably involve bribed policemen)Spunkster wrote:You can do that but it is not recommended for theft reasons.
So i will stcik to using it without immobilizer and reflash stock ECU for other car at the dealer's.
Thank you)
