Hello.
I have an Euro CRX EE8 (b16a1 engine - never sold in the US) and want to put a turbo on it. What are my possibilities to use a hondata system if I don't want to convert my original ecu to an obd1 ecu ?
Thanks in advance.
Euro EE8
Ok, but I've heard that I can't tune the stage2/3/4 system for my own.
I also had a look on the zdyne which can be directly tuned with a laptop.
For the hondata system I would need an eprom burner, right ?
Are you sure that both systems work for euro CRX ? Do you have experience with that car/that ecu ?
Thanks!
Alex
Thanks!
Alex
to be realistic and honest you will require all the aforementioned hardware AND a wide band O2 to tune ANY ecu/engine. and regardless of which oem-ecu tuning software you use, the obdI is the ecu of choice.
jumper harnesses are not necessarily required: we offer obdI ecus with the early (obd0) plugs already installed on the ecu so they plug right into the stock obd0 harness...just like the obdII-I conversions Hondata sells for the later ('96-up) Hondas.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
