My car likes to cut off at very low thottle percentage, around 5-10%. It seems like the fuel shuts off. I noticed that the tps sensor was changed on my throttle body so I am guessing it is out of adjustment.
My question is could this lead to a loss of power? I just had my hondata tuned with this problem on the car.
It seems that my car didnt make as much power as should be expected.
I have:
b16 head p&p
skunk2 manifold, skunk2 stage 1 cams/aem gears
slightly milled
b18c1 block bored .25 over
spoon balanced jdm itr pistons
polished and balanced crank
slightly milled
i/h/e
msd ignition/coil
unorthodox underdrive pulley w/ no ac
lightned flywheel/ hyper clutch
hondata s100 w/ perfect air/fuel graphs
made 160 peak hp!
What do you think?
tps problem? low dyno chart?
cecilseahawks
94 del sol
B18c1 block, b16a head
.25 spoon balanced jdm itr pistons
skunk2 stage 1 cams
p&p
skunk2 stage 1 cams
p&p
TPS & power
The setting of the TPS has no effect on power, as long as it reads 25% or so at full throttle.
There's a lot more to an engine that just a sum of parts. How the engine was built, clearances, materials and matching all the parts to work together make a big difference. The oil used and method of break in alter the power of the engine. A lot of after market parts make less hp than stock, so sometimes it is far better to use what Honda has provided. My B18C5 which was 100% stock after from a custom header and iceman intake made 185 whp.
