Hondata Boost Control solenoid - Problem
Import-JDM.com
Hello Buddys,
I have one problem with tune my S300 for Boost Control.
I put 11 Psi for 1st, 2nd and 3rd gear and it makes:
1st -> 11 psi
2nd -> 15 psi
3rd -> 18 psi
I attached two Print Screens for Low and High Table, i use the Tial Spring Large Red 0.7 BAR - 10 Psi.
Why i put same pressure for 1st, 2nd and 3rd and it makes diferent pressures in each gear ?
Thank you for your time.
Regards
Pat
1st -> 11 psi
2nd -> 15 psi
3rd -> 18 psi
Regards
Pat
megomaniac
Import-JDM.com
Import-JDM.com
With that turbo, you are getting boost creep. You are creating more exhaust gas energy in the higher gears due to the increased engine loading.. Run less duty cycle in the upper gears and see what happens.. You could also run a smaller turbo.. :)
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
Import-JDM.com
Import-JDM.com
Import-JDM.com
