Injector trim possible someday?
fox30
Post by fox30 »
Too bad there wasn't an injector trim table in romeditor, like the Haltech ECU setup has.
Cylinder #4 on all the B18's, I've worked on at least, seem to burn hotter than cylinders 3, 2 and 1. I will tune to 14.7 and no matter what, cylinder 4 sparkplugs are always a bit whiter in color indicating leaner than the other 3. I have seen many D16 and B18 motors damaged by detonation with the #4 cylinder showing the hottest damage.
if we could tune on per cylinder table temps that would be even more perfect rather than average out all 4.
I know Haltech does it, just would like to see Hondata add it!
Injector trim would be nice to add to romeditor if its possible.
96 GSR / B18C1 Built / AEBS T-Sleeves /~~/
No stickers / no nice rims / 10.4 seconds
other hobbies: PC gaming, Half-Life, Linux Administration, MotocrossKX250, kissing big tities
RMS
Post by RMS »
cyl 4 is definately the weak one for tuning on both b and d series. over half of all engine damage we've seen is in cyl 4. trim is such an advanced feature i believe most ppl are better off tuning with cyl 4 as yardstick (good place to watch egt unless running single fogger dry n20).
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
