S/N 01744
S/V 1.3.5.4
firmware 1.00
2004 rsx-s
i had my car sitting for about 2-3 mounts now and it wont upload any thing i checking the battery, grown, all good still the same. Then i tryed to erase ecu that fail too, so i tryed the download and it works but cal is all missed up all ignition is 104.5 fuel is at 65535 and cam is at 0 Then i open the ecu up too look at the lights every thing is ok green on red blinks, but when i turn the key to on and hit f10 green and red light both blinks.
CANT UPLOAD
killerhondas
This K-Pro was not installed by Hondata, it is possible that it is an installation problem. The best thing to do would be to find the nearest K-Pro installer from the Hondata dealer list and have them check out the ECU. It may be something simple, or it could be something that requires the replacement of the ECU, K-Pro or both.
killerhondas
So i emailed Forward Thrust Engineering the only one i found on you site and they haven emailed me back so i took it upon my self to take it to work, and had one of the IC guys take a look at it. He told me that both of the IC failed and we have the parts to repace it. but i would need to reload the firmware. so where would i get one and if i cant, how much for a replacement chip. He tested the ecu also and every thing is good
