main relay buzzing with s300
holset b18c1
- Contact:
not sure whats the problem but my main relay started buzzing the same day after i tryed 2 get the car tuned?? i checked for loose gound wire found none!! thromostat valve cover tranny grounds all good!! looked in the car for loose grounds none!! tryed cranking the motor will not start any more is my s300 fired??also only with the s300 the relay buzz not with the stock ecu!! car 99 civic si with gsr turbo set up!!
holset b18c1
- Contact:
holset b18c1
- Contact:
need help
Where was your bad ground wire?
Got a new jumper harness and main relay ! Still buzzing
