speedo innacuracy
nunoctr
speedo innacuracy
Post by nunoctr »
Hi hondata,
Went to a drive in the highway and I was doing 260 km/h on the speedo.
In the datalog the car was only at 240km/h.
Today went to make a dyno and they said the car have a brutal speedo inaccuracy of more than 20Km/h.
The car is the FN2 civic and this is MAP based calibration there is in f.manager for the FN2 (with changes on fuel, ign. and cams).
What is the problem?
Nuno
Dawid S
Post by Dawid S »
The same problem here :cry:
walter
Post by walter »
Same here, on speedo 258km/h, on Datalog ~240km/h.
FN2 R-04455
SkyeHack
Post by SkyeHack »
same problem here. i was going 158mph indicated on GPS on i95 and the datalog was off
mw1978
Post by mw1978 »
I HAVE THE SaME PROBLEM! before flashpro when i drove on 6th gear and 3000rpm i had 100km NOW i have 104km/h
The race calibration in a FN2 will give an incorrect gauge speed due to the final drive. The datalog speed should be accurate. We plan to add a setting to fix this.
If you have an issue then we need to know:
- chassis type (eg FN2)
- calibration type (AFM or race)
- final drive
- gauge speed vs datalog speed vs actual speed
- actual speed determination method
- gear speed was measured in
- tire / wheel size if different from stock
nunoctr
Post by nunoctr »
Hondata wrote:The race calibration in a FN2 will give an incorrect gauge speed due to the final drive. The datalog speed should be accurate. We plan to add a setting to fix this.
- final drive
- chassis type: FN2
- calibration type: race
- final drive: OEM
- gauge speed vs datalog speed: 259km/h vs 240 km/h
- actual speed determination method: on the road
- gear speed was measured in: 6ª
- tire / wheel size if different from stock: no (stock 225-45-18)
gasss_85
Post by gasss_85 »
what about this problem??? :?: :?: :?: :?: :?: :?:
The last version of the software allows you to correct the speed.
nunoctr
Post by nunoctr »
Yes it's ok now.
I put less 7% on the dash and it's = to the VSS.
aEGo2
Post by aEGo2 »
nunoctr wrote:Yes it's ok now.
Hi bro, care to share how to do it? thanks!
nunoctr
Post by nunoctr »
you need the last beta version of the flashpro software. Then go to the "calibration" and put -7% in the dash speed.
aEGo2
Post by aEGo2 »
nunoctr wrote:you need the last beta version of the flashpro software. Then go to the "calibration" and put -7% in the dash speed.
got it thanks :D
