Code 13 and 16 after hondata install
5thgencivic
Post by 5thgencivic »
We are getting a code 13(Baro-Atmoshperic pressure sensor) and 16(injectors) after installing hondata.. The ECU is a P28. Hondata is a S200 with boost. Without the jumper, there are no codes at all..
Could I have a bad basemap? Can and should the baro be disabled if a new rom is burned? This isn't common with P28's is it? Thanks for any help you can give. We are hoping this can get resolved.
Nate
5thgencivic
I've done some researching and found my ECU doesn't have the sensor so both codes should be able to be disabled. Sorry for the wasted space :oops: Now I just need to find out if it will be ok to run a p28 basemap.
DevineCRX
Post by DevineCRX »
Yes, a p28 base map will work fine.
