raised compression over 12:1.
silverspoon1996
Post by silverspoon1996 »
Is it possible to get a basemap for higher compression?? I am knocking off idle and cant figure it out.
Garrett_si
Post by Garrett_si »
you need tu adjust the calibration
increase duty cycle, and reduce ignition timing
silverspoon1996
That sounds all fine but im not a tuner, I am just looking for a basemap to drive to the tuner. As of right now im using the race map on map setting for the K&N v2 and RH. I am going to attach my datalog so someone can take a look it breaks up in first gear and has a hessitation around 3000 rpm.
silverspoon1996
I figured out part of the problem... I was 2 quarts low on oil from all the revving I had been doing lately... It fixed the hesitation. I am still however getting up to 6 degrees knock retard.
k20z3si4dr
Post by k20z3si4dr »
silverspoon1996 wrote:I am still however getting up to 6 degrees knock retard.
thats why you do what garrett si told you to do.
