Ignition Compatibility?
Screaminz28
I have an MSD 7AL2 and wanted to make sure it will work with the hondata. I was running a FAST system and decided to try a hondata instead. Anyone know if the 7AL2 is compatible, or do I need a Digital6 or similar?
Ignition systems
If it works with stock then it will work with Hondata.
The stock ignition system usually works well up to 15-20 lbs boost. We've found that some ignition systems are fairly hard on the ignitor when you rev the engine up and then release the throttle. The ECU cuts the fuel but not the spark and it seems the spark sometimes prefers the ignitor to the cylinder. Before you ask me to implement an ignition and fuel cut I'll ask you how will your tach work if you do that.
Screaminz28
QUICKSILVER RACING
- Contact:
MSD instructions can be downloaded at http://www.msdignition.com/Screaminz28 wrote:Does anyone have a recommended way to tell me how to find out? Any wiring instructions? Thanks!
