set lambda stock
Veyron
set lambda stock
Post by Veyron »
how can I set the parameters for wideband labda if I have the original?
I'm sorry, but I don't understand the question.
Veyron
Post by Veyron »
sorry do not speak good English ... I am Italian ... :-) sorry ... anyway ...
I use the wideband stock settings I wanted to know in "closed loop" what should I set, for example:
wideband input source D10ELD
Offset -0.45
is so clear?
many thanks!
You must enter the settings for your wideband and then adjust the offset until your wideband reads the same in Smanager and on the wideband gauge.
Veyron
Post by Veyron »
grazie mille!!! ;-)
Veyron
Post by Veyron »
thank you very much!!!! ;-)
Veyron
Post by Veyron »
Why would another excuse ...:-) I can explain the function "Disable O2 Heater"? Thank you guys! :) :oops:
