Both red and green lights off on kpro board
ekhybrid
Post by ekhybrid »
I've been having this problem for awhile now.......Sometimes the red and green light goes out....preventing the car from starting. When it does work normal, the lights will go out during driving and the car still runs and drives fine. If I plug my laptop to the usb cord and kpro, the light will come on and stay on for as long as its connected to the laptop....Ive read in the trouble shooting that there might be a fault in the kpro board.....is this covered under some sort of warranty?
When posting a KPro problem with your vehicle, please include:
- serial number of your K-Pro--------- 05001255
- KManager version (not 'the latest')--------1.3.5.4
- what sort of vehicle you have-------1993 honda civic hatch K20a2
- what sort of ECU you are using--------PRB
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).-----------hybrid-racing harness......The lastest version------
- a specific description of the problem--------- I've been having this problem for awhile now.......Sometimes the red and green light goes out....preventing the car from starting. When it does work normal, the lights will go out during driving and the car still runs and drives fine. If I plug my laptop to the usb cord and kpro, the light will come on and stay on for as long as its connected to the laptop....Ive read in the trouble shooting that there might be a fault in the kpro board.....is this covered under some sort of warranty?
What is the serial number of the K-Pro?
ekhybrid
Post by ekhybrid »
I'll have to get it tommorrow. Is the seriel number located on the kpro board inside the ECU?
yes
ekhybrid
Post by ekhybrid »
here is the seriel number: 05001255
This K-Pro was not installed by Hondata. It is more than likely an installation problem. If you look on the dealer list ( http://www.hondata.com/dealers.html ) you may be able to find a K-Pro installer in your area that can take a look at it for you.
ekhybrid
Post by ekhybrid »
would resetting the firmware help at all?
You cannot reset the firmware.
ekhybrid
Post by ekhybrid »
would it help if I added that my car is k20a2 Civic hatch 1993? I"m now getting daughter board communication error. I read on here that maybe my battery is going bad?
ekhybrid
Post by ekhybrid »
I've also tried to erase the ECu and all I get is error....
Have you contacted one of the K-Pro installers listed on our dealer page to have them check it out for you?
ekhybrid
Post by ekhybrid »
No not yet....I wanted to get it running over the weekend.....I had some relatives come down....I'm working a lot so I don't have time to drive over to kingmotorsports to see if they can check it out.....I really don't want to send it out and it get lost or something. I'll update soon.
ekhybrid
Post by ekhybrid »
tried it out on another car.....same issues.
Have you taken it to a K-Pro installer yet?
ekhybrid
Post by ekhybrid »
i emailed the installer that installed the kpro on my ecu......haven't received a response yet.
