Frist off I'd like to say that I have searched this issue at length and have tried various fuel and timing retard combinations. For some reason I am only able to make 1.5psi with anti-lag I have tried settings up to:
350% fuel enrichment
-40 deg of timing
My launch rev limiter is 4000 rpm and fuel activation is 3500. I am wondering what I can do to make this work. I run a very large turbo on my car (Holset HX52, similar to a GT42). Is this just the nature of the beast or am I doing something wrong? Also how much timing can I retard without causing problems?
Any help would be great, thanks in advance :)
Anti-Lag building very little boost
spoolind16
Yes I confirmed that I put -40 timing. I will try your suggestions today and hopefully post a log.Martian wrote:post a datalog.
raise your limiter to 6000, and change fuel to 400. Did you make sure to put a -40 and not 40 in the timing field?
Is the Fuel value an actual percentage of fuel enrichment or is it similar to the fuel values in the fuel MAP? I thought I read something that said it was a percentage.
spoolind16
boostedcivicsir
spoolind16
