Engine Won't start after update and initial calibration
LK7R
Post by LK7R »
RlaeR wrote:holy crap i thought that jump starter battery thing with the car battery would be adequate so i took your suggestion and stuck in another car battery and it started right up! Thank you!
8) easyiest solution is usualy the rigth one ...
You are welcome!
cheers
Dan
LK7R
Post by LK7R »
cranny wrote:you should have the engine off with the key to on position for uploading. that is a very bad habit. i have no first hand knoledge of this phenomena , but ive read of others somewhere , damaging thier ecu's by uploading with the engine running.
Well, on the instructional DVD from Hondata was said that if you give a bit more revs and then upload, everything sould be fine - maximum would be that the engine will stop and you will have to start it again. But i agree that it is probably safer to do it without engine runing.
RlaeR
Post by RlaeR »
Yeah, I've always done it without the engine running. This was the first time it ever happened and hopefully will be the last time. I don't want to damage the ECU because of something stupid like that, that would be another big headache.
