Air temp compensation tables
Maverik
Post by Maverik »
Hi,
in Parameters/Temp Compensation there is a table for ignition compensation vs air temperature and load.
I'd like to know the definition of:
- Retard (IGN degrees pulled off?)
- low load (rpm, MAP value)
- high load (rpm, MAP value)
I had a look to the help, but I couldn't find an exhaustive answer.
Retard means the oposite of advance, meaning taking away.
Low load means part throttle and idle, High load means wide open throttle.
Maverik
Post by Maverik »
So, considering the high load ignition compensation table in the picture, am I taking away 0 degrees of timing @ 30C IAT, 5.25 degrees of timing @ 55C IAT and 10.75 degree of timing @ 80C IAT? Is that correct?
You mean, the load is calculated only by taking into consideration the throttle position? (for example something like: Low load = 0-50 % throttle opening, High load = 51-100 % throttle opening)
gigaCTR
Post by gigaCTR »
hey mate
i think hondata defines map rows 1-6 as low and 7-10 as high.
Maverik
Post by Maverik »
I'm still confused on how the ECU calculates the load: does it depends on RPM or MAP or TPS or a combination of them?
What is the load value used by the ECU to switch from low to high load tables?
Load = manifold pressure. There are additional tables which determine 'low' and 'high' load. As a guide, use the open/closed loop switch-over setting (about 80 kPa).
