nunoctr
Posts: 170 Joined: Tue May 16, 2006 12:29 pm
Post
by nunoctr » Fri May 08, 2009 5:14 pm
Hi hondata.
Thanks for this product (I have a FN2 with reflash hondata and now I will buy this).
Can the civic SI calibrations be used in the FN2 type R? or they are different?
And what is a "90 second programming time"?
Thanks again
Posts: 10616 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Fri May 08, 2009 5:43 pm
We will have calibrations for the FN2. The Civic Si calibrations will not work very well.
It takes approximately 90 seconds to program the vehicle ECU.
2xSI
Posts: 13 Joined: Sat May 09, 2009 5:43 pm
Post
by 2xSI » Sat May 09, 2009 5:49 pm
Will there be base calibrations? Do you currently have base calibrations for I/H/E and cams? I have Toruku Street Cams arriving this monday.
Current Mods:
Vibrant RH with HFC
Vibrant exhaust
Injen CAI
TBS
NST
Post
by Hondata » Sat May 09, 2009 6:47 pm
There will be a calibration for the Injen CAI + header, which should be a good starting point. However, for cams you'll need to switch to the race program (non AFM) and get it tuned.
CivicVTi
Posts: 296 Joined: Mon Dec 15, 2003 1:51 pm
Post
by CivicVTi » Sun May 10, 2009 3:09 pm
Can the AFM be completely removed and have no CELs?
Moreover, can the tuned calibration be downloaded from the ECU back to a different PC?
Post
by Hondata » Sun May 10, 2009 3:31 pm
The AFM cannot be removed because it contains the IAT.
Calibrations can be downloaded from the FlashPro back to a different PC.
CivicVTi
Post
by CivicVTi » Mon May 11, 2009 3:22 pm
Hondata wrote: The AFM cannot be removed because it contains the IAT.
Any way to bypass teh AFM restriction, especially in very high HP setups? Like using an old Honda IAT and recalibrating the software for it?
Post
by Hondata » Mon May 11, 2009 6:17 pm
Just make sure the intake tube is big enough that the AFM is not a restriction.
2xSI
Post
by 2xSI » Wed May 13, 2009 2:30 pm
Hondata wrote: There will be a calibration for the Injen CAI + header, which should be a good starting point. However, for cams you'll need to switch to the race program (non AFM) and get it tuned.
I watched the videos.
1. To tune even street cams I will have to disable the MAF and use the race program?
2. In the video Doug was using Lambda. How does this equate to AFR of 14.7 or 13? Is there a conversion factor or table?
Post
by Hondata » Thu May 14, 2009 6:58 am
1. No. You can use the AFM.
2. Lambda is the stoichiometric ratio. To convert to an air fuel ratio, multiply by 14.7
Garrett_si
Posts: 253 Joined: Wed May 17, 2006 9:49 am
Post
by Garrett_si » Fri May 15, 2009 3:39 am
does the 02 sensor on the SI is wideband?
Post
by Hondata » Fri May 15, 2009 7:11 am
Yes, it is of a semi-wideband type. It appears to read lower than the RSX wideband (perhaps down to 10.5:1 rather than 11.4:1).
Garrett_si
Post
by Garrett_si » Fri May 15, 2009 9:16 am
Hondata wrote: Yes, it is of a semi-wideband type. It appears to read lower than the RSX wideband (perhaps down to 10.5:1 rather than 11.4:1).
this is not a good news :?
do you think in the future you will add a wideband input on the flashpro (like Hptuners) or via the ECU?
soxfan143
Posts: 216 Joined: Mon Nov 12, 2007 5:09 pm
Post
by soxfan143 » Sun May 17, 2009 4:22 pm
Hondata, while using the race program, will all the readiness codes still be ready or will there be any incomplete readiness tests stored in the ECU? I ask because in MA if all the readiness codes aren't passed or ready I will fail my state inspection. Can we set the readiness codes to ready like with the kpro software?
Post
by Hondata » Mon May 18, 2009 10:46 am
At this point we do not know if it will have the same function as KPro.
