heated or non heated 02 with db15vtec and p08?
paaascal
Post by paaascal »
which o2 sensor is betteR? the heated or non heated...
i have a dsport heater.. the o2 sensor is mounted where the 2 comes in to one.. i was wondering if that got hot enough to run a non heated 02 sensor
DaX
Post by DaX »
Just go with a heated...it's not that your car won't run hot enough necessarilly, it's that a heated o2 sensor heats up fast as hell y0! So while your car is still warming up, the sensor is already at operating temp.
paaascal
Post by paaascal »
how do i hook it up though? doensnt the heater turn off after a while?
i have the p08 ecu that runs 02 sensor with no heater...
DaX
Post by DaX »
hmmm...then I guess you'll have to use a non heated. there may be a way, but i'm unaware of it.
RMS
Post by RMS »
the ecu needs a couple components added. p08s are the same as JDM p30s with a few things deleted from the board.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
paaascal
Post by paaascal »
well if you know where the info is tell me lol
