Hondata and ZEX Wet Kit?
know that Hondata has the option to control nitrous using a dry kit. Is it possible to get hondata to work with the ZEX Wet kit?? I would still like to use the ZEX Nitrous Management Unit to active the nitrous and fuel, but have hondata retard timing when the nitrous is active..any ideas?
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
With your diagram, you wouldnt be sure if hondata is actually retarding the timing.
Here's what I think should be done.
1. Connect your relay #85 to +12V
2. Connect #86 to ECU A20.
3. Connect #30 to GND
4. Connect #87 to NMU GND
5. Connect ECU B8 to a switched GND.
THis set-up will allow hondata to fully control when
the nitrous operates. You also need to set-up your nitrous engagement points with your hondata.[/img]
