prelude base map calibration question
01_prelude
Hey I was wondering if anyone knows what engine the prelude base on the default calibration is. As far as I can tell we have all had this problem with the base map calibration for prelude/h22. also does anyone have a base map calibration for the h22a4? I know sleepncb7 has his calibrations on here but everyone else's doesn't seem to be attached any more. I tried sleepncb7 calibration however it feels a little funky and makes a lot of popping noises in exhaust. Thanks for any info anyone can provide
01_prelude
here is the datalog of using sleepncb7 calibrations. It wasnt very long I forgot my phone on me so I didnt want to break down too far away from home. Also was curious if I could get some of my other questions answered. Thanks.
01_prelude
01_prelude
Load the Smanager provided map for the stock h22 (yes, the one with the 450cc). In the fuel trim settings, change it to 290cc, then you'll have to decrease the whole fuel map till you reach the proper AFR. I did it by highlighting the first 5 columns of the map and decreasing till my IDLE AFR was in the 14's. Then highlight columns 6-10 and decrease (CTRL+D about 4 times) then drive/datalog. That'll get you in the safe field and you oughtta be able to tweak out the rest. The timing graph you'll want to leave alone.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
01_prelude
So I finally had some time to do a little more datalogging and maybe someone might be able to let me know about it. Also I never got my question answered on whether or not the "prelude" calibration was for a H22 or the other different motors that we run. Thanks for any information.
Is the Prelude.skl calibration any good once the fuelling is sorted?
I'm thinking of giving the same ign settings from the calibration a try in my Neptune RTP? After all, the stock base maps shipped with both boards appear to have identical ignition tables, and I have already compared the Hondata prelude.skl tables with the stock bin file from a 32870-P13-G00 prelude ecu, and found them identical.
What do you think?
What do you think?
Tim
http://www.s2kuk.com
http://www.ludegeneration.co.uk
01_prelude
