First datalog...is this normal?
dasupacat
Post by dasupacat »
Well I decided to do my first datalog today since it was about 48 deg out. I did a 3rd gear pull to redline.
From what I can see there are no knock counts, but the knock threshhold is all over the place. If someone can look at my datalog I would be greatful. I'm a noob and am still learning what to look for. This can't be normal can it? I'm using the K20A2 Type-S cai dyno tuned cal from the Kmanager to start out with.
When I looked under errors I notice batt voltage was low until the rpm's climbed.
There was also a spike in a/f at low rpm at one point.
n/a 02' EP3 Civic SI Taffy white K20a2/6spd Hondata Kpro Greddy EVOTT Injen Short ram Progress springs/24 mm Rr sway camber kit Tokiko Dspecs 17" Enkei RPF1's JDM CTR 6spd knob/boot Braille B2015 batt. s/s braided clutch/brake lines
cranny
Post by cranny »
wow , mega lean man. there is no type s stock CAI cal. there is a k20a2 stock tuned , and k20a2 cai. be more specific.
another guy that cant do a datalog. whats with people rolling on the thottle? get the car at 2k rpm , FLOOR IT and hold it till redline. you started to throttle it at 2k , and didnt reach WOT till like 3600 , makes the datalog useless. need another one done properly.
dasupacat
Post by dasupacat »
My bad it is K20A2 dyno tuned cai.
Like I said this is my first time doing this. I thought it was 3rd gear at 3k then floor it.
Btw my tps read 100% at 3273 rpm
cranny
Post by cranny »
sorry had a long day man , lol. get the car at 2krpm 3rd gear , floor it and dont let off till redline.
dasupacat
Post by dasupacat »
I hear that. I will try another run and post a datalog.
I have a dumb question. When datalogging should the car be in open loop or closed?
fonz600
Post by fonz600 »
It'll switch to open loop automatically when your doing WOT runs so don't worry bout that.
If your tuning part throttle it needs to be switched to open loop through Kmanager.
