o2 sensor error, anyway to disable the error code
devilz
Post by devilz »
When I go off throttle at sometimes I get the O2 sensor error poping up,, only at off throttle driving at high revs, the tune is pretty perfect at normal driving, and the error only comes up once in a while.
Anyway of disabling this error?? or what parts of the tune should I be looking at altering to solve this problem (or is it just a falty sensor or just a rich/lean problem at off throttle?)
o2 is running is open loop mode, so i didnt think it would be reading any of the O2 readings anyway?
H22A Turbo Prelude
devilz
Post by devilz »
its a P08 Ecu (S200 hondata) in a 92 prelude, turbo (odb1 model, no need for any harness)
incase that info helps...
H22A Turbo Prelude
APZGSR
Post by APZGSR »
your problem is that afther the tunnig you have to put it in close loop but the millibars for that to read is like 100mlbars that way you don't get the mil. :wink:
that hapen to me to and took me a some time and an o2 to solved.
Is not what you get, is what you do
