i'm having a problem with vtec engauging, i'm using a pr4 s300 ecu, the board isn't enabled for vtec so i'm using a relay from the secondary vtec out put and have tried both a20 and a15 pins and can not get vtec to engauge. i've checked and confirmed all my wire connections and confirmed that the relay is working also. is there something i'm missing here, i've even hooked a multi meter up and confirmed that the ecu isn't sending a signal to the relay.
any help or solutions would be very well thanked
Help With outputs?
V-Spec race development
MrRide2Low
you are sure you got all the right components for the vtec conversion what board numbers are the 2 ecu's there are 3 board types?
http://www.xenocron.com/install/11f0.htm <-11F0 Install
http://www.xenocron.com/install/1720.htm <-1720
http://www.xenocron.com/install/1980.htm <-1980
Hope this helps!
Hope this helps!
MrRide2Low
