So I have finally put my car all back together, after putting a LSD in my Tranny, putting a new ACT clutch and Flywheel, and building my bottom end with all Eagle Products. I am by no means an expert at tuning and am needing a little help. I am having a really hard time getting a smooth idle.
I've checked everything that I can, from setting the idle per the hanes manual, checking for a vacume leak, the ignition timing, and now two different sets of Sparkplugs. So I'm thinking that it is something in my tune. Any help would be appreciated. oh also I don't have my exhaust connected its just a strait dump
B18C1 with Eagle rods and crank, Stock GSR head (that'll be next)
with a TD04 Turbo at 12 lbs on the spring.
I have also attached my datalog which is about 2 min (if you need longer just let me know) and my current tune.
Thanks,
Idle Problems
Idle Problems
