datalogging fuel pressure with analog#2 question
boostedcivicsir
i have already cut the resistors out for using the eld to monitor wideband.
i know it is pretty straight forward but just want to make sure all that i need to do is cut r2 and r3 out. and will this have adverse effects? thankyou.
boostedcivicsir
you talking about this sensor that works with the auto meter or aem gauges???
http://autometer.com/cat_accessoriesdetail.aspx?vid=27
You applying 5volts from the regulated circuit from the ECU i take itboostedcivicsir wrote:aem fuel pressure transducer. then attach a voltage to a pressure and you can log it. much like the map sensor does. just using the analog input.
That is nice and simpe wish i looked at doing it ealier
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
boostedcivicsir
boostedcivicsir
V-Spec race development
Did you have to splice your wiring for the pressure gauge to the TPS d20 and d22? how many wires are there off the transducer 2 or 3. I have a Defi fuel pressure gauge already hookup in my car but it reads in metric and not in PSI w/c is sucks, can I use that sender and splice my wirings on there and hook them to D20 and D22? thanks.
boostedcivicsir
i cant remember what wire is what dont have the helms in front of me, but d20 and 22 are the 5v and ground, so the red and black have to go to them. the green wire goes to analog input2. (3 wires total)
yes you splice, as that is your tps input. if you cut them you loose tps.
as far as using your defi stuff im not 100% sure on how to make it work.
boostedcivicsir
