Vss problem
Vss problem
I searched and did not find anything that could help me with my problem. I own a 88 crx hf that is tuned on hondata s300 (p28) running 1.4 smanager. My problem is that when tuning my tuner and I noticed that my vss was not being datalogged. I have a wire running from the vss signal to the b10 pin on the ecu and to the cluster. The cluster is reading fine but the ecu is not reading anything. I do not have any error codes. I am using the same wire from the vss to both the cluster and ecu (one wire is split to feed cluster and ecu) so I know the wire is sending the proper signal because the cluster does work. I am pretty frustrated because I really want to use boost control and launch control. If anyone can think of anything that it could be please give your 2 cents.
