Looking for a base map for a Poormans Stroked Type R
Stokes
Post by Stokes »
Gsr block 81mm p30 pistons
ls Crank ls rods w/arp rodbolts
arp headstuds
B16 head w/mild P&P, supertech valvetrain,and 3 angle vlave job
2001 itr cams skunk 2 cam gears
2000 si intake manifold and throttle body
Aem fuel rail, B&M reg, walbro pump, with stock injectors
hytech header w/3" collector stepped to 2.5 ran to a worldsport 2 muffler
just seeing if theres anyone out there with a good map for this setup THANKS
OTT
Post by OTT »
what injects are you using? and whatr fuel pressure?
