Injectors cut in and out.
Finally got my new H22a into my EG but now when I hold the throttle steady he injectors seem to cut out and the car bogs and the the duty cycle goes back up from zero and its fine fo a few more seconds. Please help ASAP I would like to get this car on the road.
I put my s300 into a virgin p28 and I am still not able to run the car with the s300. The car will start and run but if i give it throttle and hold it steady it will cut out and drop down to idle and then jump back up. The ECU blinks a red light when it is turned on and stays green the rest of the time. Any suggestions would be greatly appreciated. Again with a stock p13 in the car it runs fine. This is in an EG.
I will post my datalog tm night.
cardinal811
I had this issue before going solid rear mount. The motor is rocking and smashing the TPS. Check to see if cracked or if it's not a rivit styled one check and see if the screws are loose. Whats happening is that you push the peddle and its clocking the tps it self advanced. Then when you hold it steady the spring return pressure on the TPS rocks back more than it should and you have -voltage and the Injectors cut out
i have this exact problem! i fixed it by calibrating the minimum and max readings of the TPS.EconoBox wrote:I put my s300 into a virgin p28 and I am still not able to run the car with the s300. The car will start and run but if i give it throttle and hold it steady it will cut out and drop down to idle and then jump back up. The ECU blinks a red light when it is turned on and stays green the rest of the time. Any suggestions would be greatly appreciated. Again with a stock p13 in the car it runs fine. This is in an EG.
93 EG Hatchback GLi + 97 JDM H22a + OBD1A Hondata S300
