Boost control by RPM is needed
cardinal811
I've recently observed an individual that was using a alternative EM. This new EM has a boost control by RPM/load to helf steady out the creep or boost fall off and to hold it consistant. Does Hondata have anything in the work for the S300? And can you design it another way to control boost rather than using the EGR signal? It's kind of shotty at times
S300 already has boost vs. rpm vs. gear. I don't find the EGR output "shotty", it works just fine for the cars I tune. The EGR output is PWM, which is what is needed. You may want to update your software if you dont see boost vs. rpm vs. gear.
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
cardinal811
