I have a PALM TUNGSTEN W and a markspace cable.
I coundn't connect to the interface box.
TUNGSTEN W and Palmlog issue
QUICKSILVER RACING
- Contact:
Palm cable
Which cable do you have? I don't think markspace makes the correct cable for the Tugsten. The cable should be a modem cable, 9 pin, powered from the Palm, and must have electronics inside the cable to convert the voltage levels.
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
hondahatch
M505/Tungsten
QuickSilver
Does the Palm 505 has RS-232 level pin out ? Or is it TTL like the Visor ?
I notice that the Tungsten uses the same connector as the Tungsten and wondering whether you get Palmlog to work on your Tungsten ?
What cable did you use ?
Does it have any TTL to RS232 level conversion on the cable you use ?
Many thanks
Many thanks
