Duty Cycle Conversion
I hope this is an easy one. When looking over a datalog file in the Smanager software, the Duty Cycle is displayed. First off, is this is actual duty cycle taken from the ECU or an estimated duty cycle? Second, when I export the datalog into excel, the duty cycle does not carry over as one of columns in excel. Is there any way that I could get the datalogged duty cycle to export as well? If not, what is the conversion the smanager uses to find the duty cycle from the injector pulse width? Thank you.
inspector01
Sorry to bring this back, but i had a question with duty cycle...
Does your injector sizing unit make a difference on what the duty cycle is??
I am tunign a car running 750s but to get it compensated correctly, i entered it as 625s and the AFRs were about right, but datalogging says I am getting 100% duty cycle at 13.5 psi on a GT28 with low 11 afrs. I know that is a little rich, but i don't know how I could max out 750s at that low of power....
inspector01
