cal needed for greddy turbo
I have a 03 type s, with a greddy turbo kit, at 7psi, and would like to stay at 7, with 550 injectors, 3 inch down pipe, megan test pipe and a 2 3/4 exhaust. i recently added the dp and test pipe, and ever since then it hasnt been running right. i was hoping someone could help me out.
i belive i did it right. btw, i cant go past 7000 rpms for some reason. k20a2-rsx-440cc16ohm-greddy-7psi is what im running. i have a 3 inch dp, megan test pipe and a 2 and 3/4 exhaust. if i need to do anything else or add more info let me know. thanks
heres a few fuel corrections , your car falls on its face where it does cause of misfire maybe it looks like. does it pop and/or spit when this happens? try new plugs or tightening up your gap. take them out and have a look if they are black as coal. you should be running step colder plugs. bkr8's. you should do a 20 minute datalog in open loop so we can see how your cruising part of he map is performing. your long term is saying 14% so. keep an eye out while datalogging at all time in open loop with boosted car when your starting to tune. for knock and lean conditions.
no but i have messenger , crandog@hotmail.com. your duty is ok at the time of the problem , no other problems i see in your datalog , maybe someone else has something to add. id say you plugs are fouled.
