hi all i was wondering if anyone had a base map for the following set up:
2002 jdm dc5
9psi jrsc
550cc injectors
spoon 4-2
stock 2-1
kakimoto regu06r cat back
gruppe m induction
obviously anything that close will also be helpfull. cheers all.
jrsc base map needed for jdm dc5
samuel.mcdonald
samuel.mcdonald
doesnt the k20a engine found in the jdm dc5 differ to the k20a2 found in the rsx??????
_______________________________________________
K20A2
Found in:
2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP3, European)
Displacement: 1998 cc
Compression: 11.0:1
Power: 200ps/198hp (148kW) @ 7800rpm
Torque: 142ft·lbf (193N·m) @ 5600rpm
Redline: 8000pm
K20A
Found in:
2001-2007 Honda Integra Type-R (DC5)
Compression: 11.5:1
Power: 217bhp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
Redline: 8600 rpm
I-VTEC Engagement: 6200rpm
K20A2
Found in:
Compression: 11.0:1
Redline: 8000pm
K20A
Found in:
Compression: 11.5:1
Redline: 8600 rpm
samuel.mcdonald
It'll be fine. What do you think all the guys, including myself use as a base map with JRSC DC5's? There ain't a K20A JRSC base map as I asked Hondata to do one ages ago.
If you are just wanting to see if it runs it'll be ok. You will still need to get the car tuned to change the cam angles, fuel and ignition, crossover point, gear ratios etc. The rsx has wideband so it'll be fine mate.
Just make sure it's the rsx-jrsc-9PSI-650cc map and not a euro civic one.
