S300 CODE 16 AND 3
turboh22a
S300 CODE 16 AND 3
Post by turboh22a »
JUST INSTALLED PRECISION TURBO 780 CC FUEL INJECTORS NOW IM GETTING A CODE 16 AND CAR IDLES REAR ROUGH, BUT IF I TAKE CAR TO 2000 RPMS IT SEEMS TO RUN FINE. THAN I GET A CODE 3 ALDOR FOR A MAP SENSOR, IM CURRENTLY RUNNING A GM 3 BAR.. ON TOP OF THE PISTONS CYLINDER 1 IS CLEAN, 2 IS DIRTY,3 IS DIRTY, AND 4 IS ALSO DIRTY. ALSO CYLINDER 4 SMOKES WHEN YOU REMOVE THE SPARK PLUG? CAR SEEMS TO HAVE A LOT OF SMOKE AND SMELL RICH BUT PLX WIDE BAND SHOWS 14.5 AT IDLE? SOME ONE PLEASE HELP IM SO CONFUSED ON WHATS GOING ON?
turboh22a
Post by turboh22a »
sorry for the caps, my computer is on caps lock all day at work.
turboh22a
Post by turboh22a »
ill post my calabrations as soon as i get my internet at home so i can get on my laptop. im running a p72 ecu with a h22a 9.1 compression, darton sleeves stock head arp everything
turboh22a
calabrations
Post by turboh22a »
heres my settings
turboh22a
Post by turboh22a »
car runs..some reason the map sensor isnt functioning? car runs rough and smells really rich but wide band is at 14.5. any ideas. someone
turboh22a
Post by turboh22a »
i jsut installed me original map sensor and the numbers went through the roof to like 56568????my gm 3 bar was stuck at 70.. someone help with this and i keep getting map sensor codes and fuel injection codes
It sounds like you have a wiring problem. If a map sensor is wired incorrectly it will be damaged. Test your components on a known good vehicle.
