boost control option not fuctioning
bernabeguzman
Post by bernabeguzman »
:evil:
I installed my own s300 and boost control option kit by myself and the whole program has been workin great exept for when i went to go use the boost control option. i bought a gm boost solenoid which is normally closed and and have a gm 3 bar map sensor, i tryed every thing from 99 percent to 100 percent but just stays open like the solenoid is not being controled becasue the gm solendoid is normally open,
so my question is there any tricks or did i solder in something wrong. i triple checked my soleding so i know its not that. but i use transistor from radio shack i dont think that would matter.
any help would be appricated thanks honda tuners.
You cannot use transistor you get from radio shack. You need to purchase the componenets through a Hondata dealer. A GM solenoid is normally open.
bernabeguzman
transistor
a transitor is a transistor i dont think thats my problem, but just to be sure ima pull one from another honda ecu and try it out
