thats funny....
i discovered that over a year ago. the p72 typically is the one that hesitates the most. same maps on a p28 never hesitate if tuning was correct.
In almost all cases, adding fuel to column 5 solves the hesitation (as much as 15% over the hondata target lambda--you will be at about 13:1 A:F)
Hesitation on the highway
Torin,TorinF wrote:thats funny....
Doing what you say for column 5, doesn't that make the columns cross each other in the 2d map? I always thought this was something you don't want to do.
QUICKSILVER RACING
- Contact:
Follow up...
Well not to long after I found my P72 ECU was causing me trouble, I got a new P28 from Hondata. Since that point I have had no more hesitation problems. I've been running on the new ECU for over a month now and driving on the highway is no longer a pain. Another thing I noticed is that I'm getting better fuel mileage as well and I'm using the same map from my P72 (this is probable because it does not shoot from lean to rich every ten seconds on the highway anymore). Anyway, my thanks goes out to everyone here who has tried to help. I hope my pain here has helped others. Good luck!
Mike
Mike
