Sticky This?
cardinal811
Sticky This?
Post by cardinal811 »
My sig says it all
15psi 336hp 278ftlbs of torque
H22A Closed Deck
cardinal811
Updating just because I see a need from others needing a good map.
AGAIN 1000cc injectors
Robs97'SH
Post by Robs97'SH »
cardinal811 wrote:Here is the 364hp 330ftlbs of torque map with a MAC valves EBC
I thank you so much, this got rid of the problem all I had to do was modify some settings such as as injector sizes and overall fuel trim.
Robs97'SH
Post by Robs97'SH »
Question: Did you see a big difference with Skunk cams compared to stock since its turbo? Also did you do extensive work on your head? I'm getting an AV Eng stage 3 block but still working out what I want to do to the head. Some say the stock cams work just a well as AFM cams and I wont see much increases in power with money spent.
cardinal811, final warning on the anti-Hondata rhetoric and offensive posts.
cardinal811
Robs97'SH wrote:Question: Did you see a big difference with Skunk cams compared to stock since its turbo? Also did you do extensive work on your head? I'm getting an AV Eng stage 3 block but still working out what I want to do to the head. Some say the stock cams work just a well as AFM cams and I wont see much increases in power with money spent.
STOCK HEAD per sea,
Skunk2 Pro 1's
Cut valve seats
Fererrea 6000 valves
Skunk2 springs and retainers
Are you using a closed deck block? AVOID BLOCK GUARDS they are over hyped and never used correctly is open deck. DART sleeves are great for open deck, but for a closed deck get the L.A. Sleeve brand. CHEAP and also they are the company that produces sleeves for the OTHER more expensive companies
AND I'm NOT ANTI HONDATA hense why I post MY map on here and help other out.
cardinal811
Hondata wrote:cardinal811
U SIR are a ignorant owner of the HONDA code, I've been on here to help others at my expense to HELP other HONDATA users, I've had more replys to my post of tunes that most users have to responses to your answers that usually result to GO SEE YOUR TUNER.
Ladies GIRLS, I'm here to help other S300 users with H and B series, most qustions I see on here that are B's I just go ahead and PM them outside of this forum, wiht out posting because of this same non-sense. DELETING POSTS.
Thats all, bann me for all I care I can get many of many proxy's or even proxy ninja cloaks to bypass the IP banns. Not a threat but just be even and level with all the users and respect to helpful advise even to those that you have sued and continue to helpmother with your SOFTWARE.
Locked. Specifically, this is what is not acceptable in your recent posts:
- Name calling ('LADIES GIRLS').
- Offensive contents (calling people 'niggers', 'cum dumpset' etc).
- Threatening (ban me and I'll use a proxy to still post on your forum). If you don't understand the meaning of a threat, look it up.
- False claims and unjustified negative comments about Hondata.
Otherwise your help on this forum is appreciated.
