Injector setup
Endles
Injector setup
Post by Endles »
can I add another 4 injectors to my hondata setup? :?:
I currently run 4x 550cc, but still have a set of my 410cc (i think) injectors
I want to combine them (1x 550 + 1x 410 per cylinder) instead of the big price tag of 850cc +++ injectors :?
turbocivicex
Post by turbocivicex »
I was also wondering the same thing, but I am wondering if you could run a pair of low imp. injectors in series, per cyl., and not need a resistor box?
Carchitect
Post by Carchitect »
The current ECU only support 4 injectors. If you need more fuel than what you have then you will need to replace with larger injectors. Installing multiple injectors will cause fuel atomization problems and can lead to other unnecessary tuning headaches. The fuel can also puddle in the manifold. The best solution would be to replace the injectors.
The resistor box would be required for the Peak and hold injectors.
Experience is what you get when you don't get what you want
08 IS350 Sport Package, Levinson, Nav, Radar cruise.
94 JZA80 6speed undergoing major weight reduction AKA 911 GT2 killer.
90 DA9 B18C5 retired auto-Xer
